-   -   What is this thing ? (http://www.hotrodders.com/forum/what-thing-228259.html)
454 Rattler 01-11-2013 01:00 PM
1 Attachment(s)
Someone must know just what this thing is and what it's used for. I DON'T !!
It's been in my "stuff" box for a couple of years now. The name on the plate is AREO-MOTIVE with a stamped model number of 5FAM.
Any ideas guys and gals ?
THANKS !
454 RATTLER
techinspector1 01-11-2013 01:11 PM
My best shot is Static Discharge Reel. Housing is grounded to pole or post or whatever, clamp is reeled out and attached to aircraft while you're working on it, to prevent static sparks that could cause an explosion or maybe wreck delicate instruments aboard.
joe_padavano 01-11-2013 01:16 PM
It's an offloader, used on an assembly line to offset the weight of a heavy tool (like an air ratchet or something) to avoid repetitive stress syndrome injuries. The clip hooks into the tool and the cable is spring loaded to allow the tool to be moved into position while the spring and cable offset the weight.
killeratrod 01-11-2013 01:17 PM
i found their site.
killeratrod 01-11-2013 01:18 PM
forgot the link. neat stuff Aero-Motive, Molex | Motion Savers | 877-832-4154
techinspector1 01-11-2013 01:22 PM
Hmmmm, shows you what I know.:rolleyes:
killeratrod 01-11-2013 01:37 PM
thru the years you forgot more then i will know haha.
496CHEVY3100 01-11-2013 04:28 PM
Their site list it as a tool balancer to off set heavy weight tools
454 Rattler 01-11-2013 04:29 PM
I gave it to a guy that was in the Air Force and he had no idea what it is.
I was thinking along the lines of what Joe_padavano is saying but everyone else thought it's for hanging your laundry or walking the dog. (and these people are in our car group).
I looked up the web site before I asked you guys but, I didn't get the info that killeratrod found.
Now I just need the time to go through the site and see if it's worth anything.
Thanks for the info. You guys are GREAT.
454 RATTLER
timothale 01-11-2013 04:35 PM
tool balancer
Some of them are adjustable for different weight's of tools. I used a lot of them when designing assembly work stations. They are also used on radial arm saws to retract the saw after making a cut. Osha regs require a RA saw to return to the rest position.
Dean Pearson 01-11-2013 06:37 PM
Very possible it is a tool balancer but it could also be a fall protection device (yoyo) that would attach to a full body harness or safety belt in the old days.
If the cable spools out easily I would lean that direction, if it is hard to pull out or is adjustable as far as how hard to pull out it is it could be a tool balancer.
Dean.:welcome:
496CHEVY3100 01-11-2013 06:50 PM
Dean.:welcome:
Go to aero motive Web site it has picture ,decription and intended use ,listed as a weight balancer,but it has ben discontinued does not meet Material Saftey Data ( OSHA )
