What is this thing ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2013, 02:00 PM
454 Rattler's Avatar
NEVER SATISFIED !!
Someone must know just what this thing is and what it's used for. I DON'T !!
It's been in my "stuff" box for a couple of years now. The name on the plate is AREO-MOTIVE with a stamped model number of 5FAM.
Any ideas guys and gals ?
THANKS !
454 RATTLER
Name:	what is it.jpg
Old 01-11-2013, 02:11 PM
techinspector1's Avatar
Wiki Edits: 326
My best shot is Static Discharge Reel. Housing is grounded to pole or post or whatever, clamp is reeled out and attached to aircraft while you're working on it, to prevent static sparks that could cause an explosion or maybe wreck delicate instruments aboard.
Old 01-11-2013, 02:16 PM
It's an offloader, used on an assembly line to offset the weight of a heavy tool (like an air ratchet or something) to avoid repetitive stress syndrome injuries. The clip hooks into the tool and the cable is spring loaded to allow the tool to be moved into position while the spring and cable offset the weight.
Old 01-11-2013, 02:17 PM
Banned
i found their site.
Old 01-11-2013, 02:18 PM
Banned
forgot the link. neat stuff Aero-Motive, Molex | Motion Savers | 877-832-4154
Old 01-11-2013, 02:22 PM
Wiki Edits: 326
Hmmmm, shows you what I know.
Old 01-11-2013, 02:37 PM
Banned
thru the years you forgot more then i will know haha.
Old 01-11-2013, 05:28 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Their site list it as a tool balancer to off set heavy weight tools
Old 01-11-2013, 05:29 PM
NEVER SATISFIED !!
I gave it to a guy that was in the Air Force and he had no idea what it is.
I was thinking along the lines of what Joe_padavano is saying but everyone else thought it's for hanging your laundry or walking the dog. (and these people are in our car group).
I looked up the web site before I asked you guys but, I didn't get the info that killeratrod found.
Now I just need the time to go through the site and see if it's worth anything.
Thanks for the info. You guys are GREAT.
454 RATTLER
Old 01-11-2013, 05:35 PM
Wiki Edits: 27
tool balancer
Some of them are adjustable for different weight's of tools. I used a lot of them when designing assembly work stations. They are also used on radial arm saws to retract the saw after making a cut. Osha regs require a RA saw to return to the rest position.
Old 01-11-2013, 07:37 PM
Very possible it is a tool balancer but it could also be a fall protection device (yoyo) that would attach to a full body harness or safety belt in the old days.
If the cable spools out easily I would lean that direction, if it is hard to pull out or is adjustable as far as how hard to pull out it is it could be a tool balancer.
Dean.
Old 01-11-2013, 07:50 PM
Built Not Bought
Dean.
Go to aero motive Web site it has picture ,decription and intended use ,listed as a weight balancer,but it has ben discontinued does not meet Material Saftey Data ( OSHA )
Old 05-01-2014, 03:37 PM
Semper Gumby
Wiki Edits: 2
When I casually glanced at the model number 5FAM, I thot it said "SPAM"
Old 05-02-2014, 10:14 PM
Actually aircraft grounding wire reels do look very simular. The give away that it was not a ground wire reel was the data plate that gave a weight capacity and a grounding wire would have a copper or copper coated squeeze clamp instead of a caribiner. I only worked on airplanes and helicopters for about 20 years.
Old 01-09-2015, 10:33 AM
Jmark's Avatar
Yes, I know it's an old post but I saw the picture on todays posts and have almost the identical thing screwed to the outside wall of my shop. Mine is even blue too! 'cept mine is a retractable clothes line! ROFLMAO. I have it strung across the yard to my 8' wind mill for the birds to land on.
What is this thing? Silver Surfer Suspension - Brakes - Steering 4 03-19-2012 11:42 AM
need help, how do i get this thing off awert Suspension - Brakes - Steering 7 08-25-2011 10:36 AM
Please help. What is this thing? LittlePwny Engine 11 09-09-2009 04:42 PM
Is this a good thing or a bad thing? Rob Keller Off-Topic 4 04-30-2007 10:54 PM
please tell me what this thing is notmrgoodwrench Transmission - Rearend 3 06-19-2005 03:12 PM
