what are those holley adjustable main metering blocks called? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2008, 01:30 PM
and, are they worth it? http://cgi.ebay.com/ebaymotors/Percy...QQcmdZViewItem
Old 12-28-2008, 02:40 PM
quick change
is it quick change. If you do allot of tuning it would be. You can do it with the carb still on the car
Old 12-29-2008, 09:33 AM
woodz428's Avatar
Troll Hunter
I agree, IF you do a lot of tuning. IF you are constantly changing your set-up and need to tailor it regularly...it's probably worth it. IF you know little about carbs, save your money. There are plenty of good carb shops that you can send your carb to with your specifics and they will return it to you ready to go. Pro-Systems is one I know of that has had great customer acclaim. Usually you don't even need to adjust the idle mixture screws.
Holleys are pretty easy to tune if you have the experience with them, they are easy to "un-tune" if you don't.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
SBC Block Questions Mustangsaly Engine 14 06-23-2005 10:14 AM
Holley metering block identification newchevyman Engine 0 08-28-2003 10:06 PM
Holley Metering Blocks MI2600 Engine 3 03-08-2003 11:24 AM
