What Thread is in Sachs Slave Cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2013, 02:22 PM
I bought a Sacks SH6028 Clutch Slave Cylinder and I am at a loss to identify the threads where the fluids enter -- A rough estimate of the size is 13 or 14mm with a very fine pitch and it appears straight -- I will need an adapter to either AN-4, 1/8" NPT, or 1/4 NPT
Old 05-18-2013, 09:30 PM
In case this ends up helping someone else:
I could not find an adapter so I took the cylinder apart and step drilled (7/16 - 1/2 - 37/64) the original ports threads out, then taped it 3/8" NPT -- 15 minute job including reassembly
bleeding slave cylinder tbelltim Suspension - Brakes - Steering 5 07-09-2007 03:22 PM
Hydraulic Slave cylinder DonC Transmission - Rearend 8 03-25-2007 09:17 AM
Slave Cylinder Leak nova69 Suspension - Brakes - Steering 6 10-05-2006 07:25 PM
clutch slave cylinder 1963duce100 Transmission - Rearend 2 07-26-2005 08:13 AM
slave cylinder Super Chevy Transmission - Rearend 6 01-04-2004 09:43 PM
