What Thread sealant would you use radiator trans cooler - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2011, 04:49 PM
I just received a new radiator and I need to reinstall the fittings for the trans cooler lines but do not know which thread sealant is best? I have locktite blue removable thread sealer, will that work?
Old 11-08-2011, 05:22 PM
NEVER you use NOTHING on those fittings.
Old 11-08-2011, 05:27 PM
gmc1990rodder's Avatar
X2 on the nothing needed!
Old 11-08-2011, 06:13 PM
x3 on nothing needed.
Old 11-08-2011, 06:56 PM
Wow... OK. I wasn't sure, I thought it needed a sealant because the original fitting had some sort of sealer on the threads.
Just to be clear, My cooler lines push into a fitting that is screwed into the radiator and the lines are held in place by a c-clip. So the threaded area I was talking about was the fitting that screws into the radiator. Thanks for all the replies!
Old 11-08-2011, 07:35 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Hmmm, hang on a sec.
Just to be clear, you should never use any kind of sealant on a tube nut to inverted-flare fitting connection.
However, the use of sealant on the *pipe thread* end of the fitting that screws directly into the radiator cooler is OK.
Note that pipe thread is actually slightly tapered, so that it gets tighter as you turn it in.
Sealant simply helps to lubricate it and fill any voids. It also assists in preventing galvanic corrosion between dissimilar metals ... which facilitates future removal.
In other words, sealant applied to the male threads of the fitting on the LH side, but no sealant for the tube nut that screws into it.
Tube thread, on the other hand, is not tapered. In fact, it is usually the same thread as a UNF (fine thread) bolt.
As you can see in the cutaway view, the tube nut forces the flared tubing down onto an inverted seat forming a mechanical seal.
Old 11-09-2011, 05:41 AM
Great info!! Thanks!!!
So, what does the trans cooler look like inside the radiator? Photos MARTINSR Hotrodding Basics 16 10-10-2009 08:28 AM
thread sealant pena0724 Engine 20 04-29-2009 04:48 AM
External Trans Cooler, Radiator Cooler, or both? 2004R & 383 SBC Cousin_Joe Transmission - Rearend 1 02-27-2008 09:10 AM
Can I use a trans cooler only without a radiator cooler? supercab78 Transmission - Rearend 5 04-14-2005 01:46 PM
Is it safe to skip the radiator and go strait to the trans cooler? Ghetto Jet Transmission - Rearend 20 10-17-2004 09:34 AM
