What are the threads - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2008, 11:11 PM
Overdriv's Avatar
in the transmission on an early 700R4, for the cooler line fittings? Are the inverted flare fittings a metric thread?
I checked the transmission - rear end knowledge base and that page does not work. Attention Mods.
Old 06-17-2008, 11:15 PM
700R4/4L60/4L60E/4L65E
Fitting Location Thread Size Flow Direction
Upper ¼" Pipe Return/in
Lower ¼" Pipe Cooler feed/out
Old 06-17-2008, 11:23 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
If I may add, the lines and flare nut are standard 5/16 also.
Old 06-17-2008, 11:33 PM
SSedan64's Avatar
I believe they're standard inverted flare on the 700R4. Where they screw in the housing is 1/4"NPT threads. Not sure about the 2004R most of the stuff on it is metric,trans mount, torque converter etc.
Old 06-18-2008, 11:29 PM
Overdriv's Avatar
Thank you all. 1/4" NPT in the case is what I needed confirmed.
