-   -   What throttle cable bracket (http://www.hotrodders.com/forum/what-throttle-cable-bracket-42810.html)
406chevelle 07-03-2004 05:31 PM
I am running an Edelbrock Performer RPM manifold with a 750 Speed Demon carb on top of a small block chev and would like to know which throttle cable bracket will work with my setup, the stock bracket I was planning to use does not fit the manifold.
What Brand and part number (if available) does everyone else run on there setup???
406chevelle
firechicken383 07-03-2004 07:55 PM
I just use an adjustable piece by Spectre. You can get at Oreillys or from Summit or jegs for around $10-12. It mounts over the carb stud and has adjustable throttle cable and Trans cable.
Works for me:thumbup:
406chevelle 07-04-2004 12:21 AM
Hey thanks for the reply firechicken383, I had seen the Spectre setup at AZ and was wondering how well they work.
Anyone else have some recommendations???
Has anyone used the Edelbrock universal throttle bracket for Chevy, part number EDL-8031???
406chevelle
