Looks like you're gonna have to tell us!
Run some different numbers and see what happens to MPG. |
In my own experience, the best timing for fuel mileage occurs about 2* under spark knock.
agreed. best timing for mileage is the same as proper timing for the combo
Best mpg @ 2200rpm = the highest Hg you can get while actually driving......
duct tape a vacuum guage to the windshield hooked up to manifold vacuum and go for test drives on the same road with more and less total timing to find the "real world" best/highest Hg possible for your particular car (gears/tires/brake drag/tranny slip/etc) |
I like the idea with the vacuum guage! I'll try that out very soon, sounds like another great use of the old fashioned vacuum guage (makes me wonder why I didn't think of this myself... especially because I do use the guage to set idle mixture and initial timing).
My combination made 220 hp at the motor at about 4600 rpm. The graph was climbling steeply but I had a bad oil leak unto the exhaust so it starting smoking heavily. Then the fuel pressure regulator was set way too low, so it also seemed to start running out of gas (this did happen on the road later). In sept. I'll put it on the dyno again (once I finally get around to fixing the oil leak). I expect it to put out at least 250, probably more, because I can keep up with my friends 57 Chevy with a 350 in it! |
Berliner, your welcome....
mounting a vacuum guage in the car is the single most effective "gas saver" you can have(my $.02).....it can "retrain" your size 12 lead foot to go easier on the "go" pedal and keep the Hg above 12-14Hg accelerating= much much better mpg but my cars always have one because it is a great "real world/real time" diagnostic tool for the condition of the whole motor, just a couple of many examples: Hg=25 or more on a mild downshift=rings and valves are sealing fine..... vacuum at idle in drive drops off a pound=look for a minor vac leak..... needle not steady=maybe a misfire or vac leak.....(that you won't feel) |
| Distributor Tuning and Theory - Part 1 | Rick WI | Engine | 35 | 04-26-2011 12:38 AM |
| Vacuum adv.. | underdog305 | Engine | 58 | 01-30-2007 11:19 AM |
| Timing advance issues... | autonuerotic | Engine | 27 | 11-22-2006 06:51 PM |
| What's a good timing curve for a 4100lb car? | Malibu73 | Engine | 3 | 03-04-2006 12:51 AM |
| Timing problem - Help | MTMike | Engine | 1 | 11-13-2002 01:07 PM |
