What tint to use in Bondo - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2008, 09:13 AM
Jmark's Avatar
As a cabinet maker, sometimes I need to use a LOT of filler on certain woods. The hot wood now is knotty Alder. I need to use a black filler on some of the bigger knot holes when the knot falls out. What would I use to tint bondo black? Anything readily available?
Thanks.
Mark
Old 05-14-2008, 10:35 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
As strange as it may seem I would try a majic marker..that is kind of a dye and would penetrate into the bondo..You may even be able to draw out a nice knothole..
Sam
Old 05-14-2008, 01:17 PM
Last journal entry: More painting pics
Would something like this work?
http://www.uscomposites.com/pigments.html
I've used it in resin and while it extends curing time and tends to gum up sandpaper a bit more than usual it might work for you.
Old 05-14-2008, 04:50 PM
Jmark's Avatar
Thanks, I'll look into them. Most of the knots and cool grain stuff is black to begin with. I can buy black walnut putty but have not looked at it yet. Figured a pint won't go far since I have 65 raised panel doors to do. LOL
Old 05-16-2008, 07:48 AM
Your best bet would be to use Evercoat's Featherfill G2 polyester primer that is available in black. You could easily brush, spread, or spray this stuff on and I'm sure it will be enough build to fill your grain and divits around the knots. Put the parts in the sun for an hour or two after you apply and it'll be ready for sanding. This is the only polyester product I know of that's black.
Old 05-16-2008, 12:01 PM
Magic Markers are actually very dark purple.
Shane
Quality of Bondo bartamos Body - Exterior 16 10-24-2006 05:22 PM
Removing old bondo arionrjw Body - Exterior 5 12-23-2005 01:16 AM
Removing old bondo arionrjw Body - Exterior 1 12-21-2005 09:48 PM
Bondo vs Dynatron ChrisMiddleron Body - Exterior 10 08-29-2003 05:07 AM
How long does it take thin amounts of bondo to crack? stonedchihuahua Body - Exterior 14 07-12-2003 09:02 PM
