what tool to use for a bubble flare?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2009, 05:35 PM
Can I use the same tool as I do for a double flare? I want to flare a line for a car and one end has a double flare and the other is a bubble flare.
Old 05-04-2009, 05:58 PM
powerrodsmike's Avatar
Wiki Edits: 161
A real bubble flare is slightly different, but using the bubble part of your regular flare tool will work.
Usually bubble flares are metric, but I know the newer cars now use them too.
Later, mikey
BE different....ACT normal.
Old 05-04-2009, 06:19 PM
Just buy a line with bubble flares on both ends already - napa has them. Cut the one end off and double flare. The 3/16" set up will work on those lines. I also do that if I have to connect lines with bubbles flares at both ends and use double flares for a double flared union in between.
They use oddball fittings sometimes with the bubble flares and the original fittings from the lines your replacing may need to be reused.
Old 05-04-2009, 06:44 PM
Mastercool tool kit # 71475 ( which I have ) makes 4 different style flares
They run about $275 on eBay ...
They make the BEST flares I have ever done ... 1 st time out.
I love mine
Old 05-09-2009, 11:37 AM
327 / 350 hp's Avatar
Hi SG ,,If you already flare, you just need the bubble flare adapt.. 327 350hp
Tips for shop layouts and tool purchases. schnitz Garage - Tools 9 10-18-2010 11:19 PM
Brake Flare Tool Compromise S10 Racer Garage - Tools 3 03-26-2009 07:21 AM
blaster vacuum 71corvette Body - Exterior 6 12-23-2007 07:24 PM
Flare tool choices for hobbyist BIGSKY Garage - Tools 10 11-27-2005 07:04 PM
Best tubing flare tool? firstgenbird Suspension - Brakes - Steering 4 04-05-2005 07:54 PM
