Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What tools for 4L60E rebuild?
Old 01-30-2005, 09:53 AM
ronb's Avatar
ronb ronb is offline
Originally posted by AMDAP
Yeah, I kind of figured that they were about as cheap as they could get. Just had to ask. You know anything about the bushings ronb? Thanks by the way!
full bushing driver sets are expensive $300-400 dollars, however there are sets made specifically for the 4L60/700R4 cost around $100-200, I think the link you had earlier in this thread had this set? or when you remove your drum inspect it for wear from the 2/4 band, you may need a new one? if this is the case when you get a new one it should have new bushings in it so that will be 2 bushings you will not need to worry about? or if you have a mechanic buddy`s that might have the drivers they will lend you? I myself custom make mine on a lathe from aluminum round stock!
