What top end combo? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2006, 04:28 AM
New Member
What top end combo?
Well this is what I got I have a 77 chevy truck with a 350 bored 60 over. Stock rods. 350 trubo trans. This is my problem I build the engine about 2 years ago. Its got the cast truck heads on it, single plane intake and a 650 carb. I went to the shop and ask what cam would they use. The guy ask what it was going in. And he said "thats a lead slead." So I dont know what cam he stuck me with but the way it runs I could out pull a bull dozer. Sounds good but no speed.
OK now for what I am asking I am looking for a top end combo. Heads cam lifers and intake you know the normal. price about 1400 to 2400. something like that. the 350 has a 11:1 compression ratio I think. I want something thats going to kick down like a car. the truck has a 2300 or 2500 stall also.
Old 01-13-2006, 10:11 AM
firestone's Avatar
http://teamrfc.gospelcom.net
If you have $2400 to spend I would go with this combonation. It is in my opinion the best bang for the buck.
AFR 180cc heads $1460
http://www.jegs.com/webapp/wcs/store...tegoryId=26569
Performer RPM air gap intake $132
http://www.jegs.com/webapp/wcs/store...1937&langId=-1
Comp Roller cam XR276HR or XR282HR $ 246 (not xr676hr like on the website, it is a misprint)
http://www.jegs.com/webapp/wcs/store...hItemId=107199
Comp roller lifters $415 (not positive these are the correct ones, you would have to check, price will be similar though)
http://www.jegs.com/webapp/wcs/store...chItemId=33233
Total:$2253
Look at the second 355 on the site below it has the XR282HR in it and makes 450 hp @ 5500 RPM and 470 tq @ 4500 RPM the XR282HR would probably work well, it is recommended that a 2000 stall is used with it, so you should be ok with yours. The smaller one would just give you a little more low end power.
http://www.airflowresearch.com/dyno/chevy_dyno.htm
Adam
Old 01-13-2006, 02:40 PM
New Member
That one has a 9 to 1 Compression wouold it matter mine being 11 to 1?
Old 01-13-2006, 02:48 PM
steve t's Avatar
ex biker, now hotrodder
maybe you need to change rear gears to lower number
Old 01-13-2006, 04:07 PM
firestone's Avatar
Yours would just make more hp, but the one I was talking about was one of the two with 9.5:1 compression. It is the second one below the one with the dyno graph.
Adam
Old 01-13-2006, 09:35 PM
How do you figure 11.1 cr? Your running pump gas @ 11.1 cr? Something does not add up.
Old 01-14-2006, 06:16 AM
New Member
well I have no clue on how to figure it out. I just know how to put a engine togather. But my friend helped me get the parts. I have build like 3 engine and 2 where stock 4.3s . But maybe you can help I know that its a 350 bored 60 over. stock crank. and the pop top pistons.The pistons are small pop top I belive the smallest poped top you can get. siverlites I think.
Old 01-14-2006, 11:14 AM
firestone's Avatar
In order to know your compression, we need the following:
we already know your cylinder diameter and stroke
combustion chamber size (cc's)
piston dome or dish (could be a flat top) (cc's)
distance piston is in the hole (in)
head gasket thickness(in)
You can then use this formula
http://www.angelfire.com/fl/procrastination/motor.html
Adam
best tranny, rear end, converter combo? Siggy_Freud Transmission - Rearend 2 08-31-2004 08:44 PM
GMC 350 Top End Oil Problem bns2002 Engine 16 12-11-2003 04:29 PM
Top End Knocking / tapet Sub_Urban_454 Engine 2 10-18-2003 03:38 PM
Edelbrock Performer - more top end nova69 Engine 1 02-14-2003 06:31 PM
camel hump...general top end questions. servant70131 Engine 6 02-14-2003 09:37 AM
