what topcoat to get? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2008, 04:56 AM
what kind of topcoat to buy? Acrylic Enamel, Urethane basecoat, Single Stage AU Acrylic Urethane, Acrylic Lacquer. I'm ready to do some sand blasting, Waterborne Wax & Grease Remover, spi Epoxy Primer, and topcoat, do i need to clearcoat the topcoat? the area I'm working on is the floor pan, inside trunk and under the car not the exterior. black satin, simi gloss?
how do i use the waterborne? put it on a rag and wipe?
Old 11-27-2008, 11:46 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
For those areas all that you really need to do is put on 2 wet coats of epoxy..good practice to do that and work on spray gun adjustment until you get it to lay out wet and slick..I use the W&G remover as the final wipe before I paint..
Hope this helps...Once you get to the point of blocking then hit us again with more questions.
Sam
Can primer be left without a topcoat? ScotY Body - Exterior 9 10-28-2008 08:53 AM
Temporary topcoat Silverback Body - Exterior 5 03-21-2007 07:36 AM
Block Sanding Before Topcoat nova69 Body - Exterior 3 06-02-2006 12:55 PM
Would rattle can paint last as a topcoat over POR-15 ?? STATUTORY GRAPE Body - Exterior 7 02-08-2005 06:14 PM
when to topcoat after epoxy primer? brauler73 Body - Exterior 0 09-02-2003 12:48 AM
