What Traction Bars you got? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2012, 10:07 AM
Traction bars - old school, new school, let me know what you have and like and why. I need to decide on a pair.
I have a standard 9" rear and I'm not dragging or racing but want something non-welded (bolt on) that looks nice (old school) and will keep the rear from buckling or wheel hop.
Old 03-31-2012, 10:09 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
get some of these and dont look back
Old 03-31-2012, 10:35 AM
Let me add: I have NO wheel hop with these new mid-eye leafs (I think they're 4 leaf but you may see in the picture I just took). I had "slap on" bars that welded to the subframe; however, as you can see in the picture, with the new subframe connectors now in place, the slap on bars were too long (from axle to the subframe connector base).
So I thinking I'll just get a pair of non-weld bars like these $50 Lakewoods from Summit. http://www.summitracing.com/parts/LAK-20470/
[IMG][/IMG] [IMG][/IMG]
Old 03-31-2012, 12:06 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
moving to suspension
Old 03-31-2012, 01:44 PM
& matts38chev
so the pics are the current set up?
if so, I would make a rod/bar that goes from the bracket on the bottom of the u-bolts, to the back of sub connectors
also: is that a wheel cyl. or axle seal leaking
Old 04-01-2012, 06:49 AM
zbhover's Avatar
V8 Beetle & Hovercrafts
I made a set of traction bars for our V8 beetle with a ford 8.8" rear end, it wasn't too bad to do. I had to buy the tubing, but I had the rest of the steel laying around, and the heim joints came from McMaster Carr.
You can see more pics of them on my website at:
http://www.v8beetleresource.com/chassis19.html
and
http://www.v8beetleresource.com/chassis20.html
Zachb
V8 Beetle Website:
Hovercraft Website:
zbcreations.com
Old 04-01-2012, 08:15 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 Build a set or go with the cal-tracs, i wouldn't mess with those Lakwoods IMHO. Did you put any welds on the connectors or just use the bolts ? And another X2 on that leak.
Cole
Old 04-12-2012, 07:29 AM
Wiki Edits: 27
traction bars
I was at the salvage yard the other day and saw some beefy factory locator bars under a couple of 4 x 4 suv's. coil spring rears, non adjustable. The car would have to be supported by the axles when doing the locations for mounting the brackets. In the 50's we used non adjustable bars.
Old 04-26-2012, 11:04 AM
heres a good Cal-trac how-to
http://www.hotrodsandhemis.com/Traction.html
Old 07-28-2012, 03:23 PM
gonna run some home made 1" inside diameter bearings as sliders on a pocket kit on a 55 with trailing arms for ladder bars. it was funny someone tried to tell me that trailing arms can't be used because they will bend with the rotational force of the axle housing. i started laughing. i guess they didn't work on c-10 trucks back in the day either...lol. what purpose did the torque tube do on the classic old school pre 55 cars. yeah, apparently they had very good traction. but the slider on the front half is so it doesn't bind. axle floaters function as well
traction bars nastypurplenova Hotrodding Basics 1 12-10-2010 07:50 PM
lift bars and traction bars hause Suspension - Brakes - Steering 1 10-05-2006 01:50 PM
IRS traction bars 1969NovaSS Suspension - Brakes - Steering 2 10-05-2006 12:00 AM
Traction Bars or Ladder bars JamesRS Transmission - Rearend 1 07-19-2005 05:57 PM
Traction bars nd500 Transmission - Rearend 4 04-09-2003 06:01 AM
