what tranny for my 383? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2006, 11:59 AM
just wondering what size tranny is should run on my 79 vette im swaping the 350 motor for a more powerful 383 stroker and i was wandering in i could use a turbo 350 tranny or a turbo 400 or another kind thank you for the help.
Old 12-06-2006, 01:23 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
Turbo 350 is fine, but if you want insurance make sure you upgrade the unit. TH400 isn't required in my opinion.
K
Old 12-06-2006, 08:17 PM
PRO 48 fleetline's Avatar
Last journal entry: Csr Electric Water pump
im bulding a 421SB chevy and i just purchased a fresh 350 tranny that im going to go through just in case and up grade some and run a value body and bigger internals but yeah 350 will be a great set up ecs if racing and its not in a real heavy car the 350 runs a better first gear to launch the car than a 400 i have a 400 in my 56 behind a 350 hp 327 a little over kill but works great the 400 has a little taller first gear but they can be worked either one to do the job great
Old 12-11-2006, 12:06 PM
LordMaximo's Avatar
Last journal entry: Painting
Originally Posted by PRO 48 fleetline
im building a 421SB Chevy and i just purchased a fresh 350 tranny that im going to go through just in case and up grade some and run a value body and bigger internals but yeah 350 will be a great set up ecs if racing and its not in a real heavy car the 350 runs a better first gear to launch the car than a 400 i have a 400 in my 56 behind a 350 hp 327 a little over kill but works great the 400 has a little taller first gear but they can be worked either one to do the job great
Now that you are building a street creeper, you need to look at torque converters and maybe the gearvendors OD unit for all that power. The T350 is a good and sound unit, as long as you have the accompanying third member for the job. if your final drive is a tall one, you are now limited to the max rpm of your assembly. I would recommend an OD unit and some good highway gears for this gas crisis we are in.
You do want to enjoy that power and be able to go places don't you?
Old 12-12-2006, 04:33 PM
tranny choosing
in my opinion use a 400 turbo because i had a 350 turbo and ripped the gears in two. you might lose about 20 horsepower but you will have a strong tranny. i also recomend a stage two transpak kit from b@m it will make it shift hard and fast. good luck
2004R tranny sotxpanrider Transmission - Rearend 0 05-20-2006 08:49 PM
Tranny update/Torque converter question RObs71Nova Transmission - Rearend 5 12-16-2004 09:37 AM
Tranny pan bolts and tranny pan ufo entropy Transmission - Rearend 6 10-06-2004 10:26 PM
What makes a 383 so much more expensive? Chevy21 Engine 12 09-30-2004 08:55 PM
70 roadrunner engine and tranny Oddi Engine 1 11-23-2001 12:38 PM
