-   -   What Trans? (http://www.hotrodders.com/forum/what-trans-224691.html)
1badchevy 10-05-2012 03:11 PM
What Trans?
Quick question. What trans came in the 84 Delta 88. I thought it had a th350 but someone told me it had the th200 which, refresh me if im wrong, was such a freekin turrrd. Thanks
LATECH 10-05-2012 04:45 PM
If it is a 3 speed, it is most likely a TH 250 . If you have a 4 speed, its a 2004r which can be a decent performer for the street with a few mods.
GypsyR 10-05-2012 09:42 PM
200R4. They came two flavors though, with and without OD. Most common seems to be the regular non-OD version.
66GMC 10-05-2012 10:29 PM
I'm pretty sure that:
The 3-speed was the THM200
The 4-speed was a THM200-4R
This Wikipedia article seems to support my theory.
cobalt327 10-06-2012 12:08 AM
Take a glance under the car, then take a look here to pin it down. Just be careful to not be fooled into thinking a TH250 is a TH350. The TH250 looks almost identical to the TH350 externally- same size, same oil pan. But unlike the TH350, it has a band adjuster stud/lock nut on the passenger side of the case near the cooler lines.;)
1badchevy 10-07-2012 04:55 AM
ok, i bought it and checked and it is a metric trans. now i just gotta see how many times it shifts and ill be in the money. thanks for yalls help
cobalt327 10-07-2012 09:06 AM
IIRC, both the TH200C and the TH2004R have "METRIC" on their pans.
Because the TH200C has the ability to lock up the torque converter, don't be fooled by the lockup engaging into thinking it's a 4-speed. The shift indicator lens on a vehicle equipped w/a TH200C will have only 3 forward gears indicated, (something like P N D 2 1), while the TH2004R will show 4 forward gears, the last forward gear is usually circled to indicate Overdrive.
Of course this assumes the original tranny is in place- which it probably is.;)
Jim Rockford 10-08-2012 06:25 AM
A 200metric will have the same shape pan as a regular th350, only smaller and with fewer bolts, they are not crappy transmission, long as they are built right, I picked up a 77 impala with no reverse come to find out the trans was missing the frigging wave washer for the low reverse piston and had blow the seal out of the piston, i rebuilt it and added a Transgo shift CORRECTION kit to the valve body its been a really nice transmission, the lower 1st gear ratio than the TH350 really helps out with getting the car moving withthe tall rear gear, Its the main reason They installed those transmission in the big cars, lower first gear to get it moving quickly and still keeping the tall rear gear for gas mileage.
http://img.photobucket.com/albums/v1...a/IMG_1251.jpg
