What trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2012, 06:31 PM
vht vht is offline
What trans
Building a 72 chevelle, for now going with a sbc. Got a motown dart block and a set of 230 dart heads, I'll go with a 421 or 434. Aiming for around 600 to 650 HP. I want to run a 3.73 or 4.10 gear so I'm stuck on the trans right now. Don't want a 700R or 4L80 so I was leaning toward a 200R4. They say they can build them to handle 750 hp without a problem. Has anyone used 1? Extreme transmission in Cinn OH are close to me but I've been advised they won't hold up, but I've seen them in low 9 sec cars. I priced a gearvenders at 2700 or so, and then you'd still have to do a trans. Anyone have any input?
Old 10-17-2012, 08:08 PM
vht vht is offline
Sorry, I see I postrd this in the wrong section.
Old 10-17-2012, 08:52 PM
SSedan64's Avatar
If built correctly they'll hold up, beyond 800TQ is TH400, 4L80E territory.
Lonnie at Extreme Automatics builds great 2004Rs. You'll need a Min Stage 2 Trans, may need to add the Billet Input Shaft, OD Carrier & OD Ring Gear.
Fastest turbo buick with 2004r ? | TurboBuick.Com
Also Chris @CK Performance, Dave Husek @Turbo Buick Performance.
Extreme Automatics Where winning is easy
www.CKPerformance.com
Old 10-17-2012, 09:26 PM
you can add the billet pieces and extra clutches and planets to a 200r4 but its still up around 600hp torque load because everything is too light wieght but if your running big hp with your engine I would go with the 4l80 you have od for steep gears and a good torque input for this trans stock many dealers sell a stand alone trans controller cheap
Old 10-17-2012, 11:37 PM
vinniekq2's Avatar
have you considered TCIs 6 speed street fighter? I use a 3.50 final gear with a moderate 434.my trans is a tko 600. with the street fighter you could use a 3.73 or 3.55 and have a very good launch with the 2.97:1 first gear
Old 10-21-2012, 12:35 AM
F-BIRD'88's Avatar
Yada Yada Yada
Y do you need overdrive? Just use a Th400 and 3.73's or 4.10's.
The high performance engine you are trying to build does not like to cruise at a low rpm.
A glide is a big mistake in this car.
changing a Aod trans. over to a c6 trans. thndrchkn Transmission - Rearend 1 11-08-2011 06:53 PM
trans swap, 400 trans in 83 elcamino? renagade Transmission - Rearend 2 10-07-2011 09:45 AM
1992 gmc trans shot, will 1986 trans fit? Jamesace Transmission - Rearend 4 05-06-2010 02:42 AM
Synthetic Trans Fluid Mixed With Regular Trans Fluid smokey626 Transmission - Rearend 1 06-14-2009 01:33 PM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 11:14 AM
