what trans should i use?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2012, 09:19 PM
ok i have a sbc 350 bore 40 over with a comp magnum 280h cam & 323 gears in the rear end. right now i have a th350 trans in my car with a 2200-2800 stall. should i keep the th350 or should i use the 700r4 i picked up
Old 09-27-2012, 09:32 PM
SSedan64's Avatar
A 200-4R would be a better choice.
You'll need a different Crossmember & the Frame Extension but, can use the same Driveshaft. The 84-88 Montes/ElCos came with 2004Rs so finding the Crossmember & Shifter, Cable & Bracket is easy. Summit sells the Extension or you can make one.
Transmission Swap Tech
Old 09-27-2012, 09:36 PM
[QUOTE=SSedan64;1594496]A 200-4R would be a better choice.
Transmission Swap Tech[/QU
im stuck with these 2 transmissions >>th350 or700r4<<<
Old 09-27-2012, 10:18 PM
SSedan64's Avatar
Driveshaft will need to be shortened about 3" if the TH350 has 6" Tailhousing..
Need the TV Cable & Bracketry, TC Lockup kit etc.. lots of Info on here.
The 700R4 has a lower 3.06 1st gear compared to the TH350's 2.52 1st. So that will help launch/takeoff.
The 700R4's 1st to 2nd gear shift has a big drop tho' 3.06 to 1.62 ratio.
.70 4th/OD will drop the 3.23 gear down to 2.26 ratio.
changing a Aod trans. over to a c6 trans. thndrchkn Transmission - Rearend 1 11-08-2011 07:53 PM
trans swap, 400 trans in 83 elcamino? renagade Transmission - Rearend 2 10-07-2011 10:45 AM
1992 gmc trans shot, will 1986 trans fit? Jamesace Transmission - Rearend 4 05-06-2010 03:42 AM
Synthetic Trans Fluid Mixed With Regular Trans Fluid smokey626 Transmission - Rearend 1 06-14-2009 02:33 PM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 12:14 PM
