What transmission? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2005, 01:57 PM
1300
What transmission?
Comrades, it’s me again, with the my project high-speed 4 wheel drive ’59 Caddy (can not invent a good name for it, please help)
So, we have resolute that its engine must be Cadillac 500 engine with twin turbo kit. And what should be its transmission?
Old 02-15-2005, 03:37 PM
BOBCRMAN@aol.com's Avatar
Only rear wheel trans that will take 500 cubes would be a GM 400 turbohydramatic.
Old 02-15-2005, 03:44 PM
1300
It's upgradable?
nevertheless It would be desirable for something permitting completely to realize all power.
Old 02-15-2005, 06:36 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
there are many stronger parts for the t-400.
If you are to use twin turbos , you want a strong t-400
Old 02-15-2005, 10:11 PM
1300
It seems, three speeds will not make available all its capabilities.
It is necessary generally to consider the drivetrain as a whole, and not just transmission.
So: what we must make with the 4-wheel drive? (Whence take a transfer case and front driving axle?) Me recommended swap them from S-series Chevy. And, If we shall use twin turbo, rear end should undertake updates too…perhaps.
