What Transmission? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2006, 07:06 AM
New Member
What Transmission?
Well I am a chevy man dont play much with fords. My grand paw has a 79 ford pickup truck its got a 5.0 in it that was out of a car the transmission is the one that came in it. its sliping and I need to look into rebuilding or getting one. What transmission is in it? Its 2 wheel drive 1/2 truck.
Old 01-22-2006, 09:17 AM
thewrongshop@yahoo.com
C4 or C6 is my guess, I don't mess with 4ord's
Old 01-22-2006, 11:24 AM
Crosley's Avatar
Wiki Edits: 1659
it would be better to know what year , make the tranny & engine came from to help ID the stuff.
Old 01-22-2006, 12:03 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
You said that the trans was still original to the 79 F150, right?
I think it would be a c-6, and this page "backs me up" on that:
http://www.transmissioncenter.net/Ve...Index.htm#FORD
Other possibilities (if someone has swapped it in) might be a C4 or an FMX
C6: 1-piece aluminum case
C4: 2-piece aluminum case (bellhousing is removable ... from the inside).
FMX: 2-piece ... bellhousing is usually aluminum, and the trans is cast iron. The trans is bolted to the bellhousing in a similar fashion to a manual transmission ... 4 bolts on the outside of the bellhousing
Have a look at pan shapes here as well:
http://www.transmissioncenter.net/PanShapes.htm
Old 01-22-2006, 03:51 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
You are not clear as to whether the trans is a 79 truck trans or the one from the unknown 5.0 car.
Be advised that 302s and 5.0s have different balance factors and require different flexplates.
You should look under the vehicle and determine the trans type by oil pan shape and embossed lettering on it, and look at the balance weight on the flexplate.
94 Dodge Transmission Electronics problem? Native Gearhead Transmission - Rearend 7 10-17-2006 10:00 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
transmission oil type. TVR383 Transmission - Rearend 3 06-05-2005 09:28 AM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
83 Z28 Transmission - YIKES! crandaz28 Transmission - Rearend 4 11-25-2003 07:43 AM
