what transmission can i use fro my chevy 235 inline 6 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2011, 06:22 PM
Hi I have a 1954 chevy Bel air and i want to keep the 235 in-line 6 it has but would like to change the transmission.What transmission can i use for it?
Old 05-05-2011, 07:16 PM
LATECH's Avatar
Standard or automatic?
Old 05-05-2011, 07:21 PM
LATECH's Avatar
Look Here.
http://www.adchevy.com/techtips/t5swap/
Looks pretty cut and dried. As for an automatic....
Old 05-05-2011, 09:16 PM
Automatic
Automatic transmission
Old 05-05-2011, 09:39 PM
carlos 1950s,
If you want to change to a newer transmission it will be tough with the old 235. You could change to a standard transmission but you will need to change the bellhousing. Add clutch linkage and shift linkage. The steering column will need to be changed also. And you will need to install a pilot bushing in the crankshaft. Then have a driveshaft built to fit.
A LOT OF WORK but all possible with enough time and money.
Scholman
Old 05-06-2011, 03:17 PM
First thing you need to do is confirm you have a 1954 motor. Don't take anything for granted, there is a very good posibility that your original motor was replaced with a later one.
I find it hard to believe that no one makes an adapter. Do some research and I think you will find something.
Old 05-06-2011, 03:20 PM
Here is one I found in 30 seconds on Google. http://www.transmissionadapters.com/Pricing.htm
Old 05-06-2011, 04:28 PM
Lots of people playing this game at www.inliners.org ... check out their forum.
Old 05-09-2011, 09:04 AM
I also would look for a t5 out of a 80s camaro with a v8. Don't for get to get the bellhousing and clutch slave.
Old 05-09-2011, 12:03 PM
i want to make it automatic.
But what if i want to make it automatic?
Old 05-09-2011, 12:21 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you're going to go w/an automatic transmission, my opinion is to do it right and use a TH2004R. Adaptor ($350) and starter ($60)- http://stoveboltengineco.com/ Prolly others as well.
Of course you can also use the cast iron Powerglide that was used behind the 235 originally...
Old 05-09-2011, 01:11 PM
Wiki Edits: 31
Don't forget that it is a torque tube drivetrain. if you go late model, then you need a rear end and drive shaft also... If you just want an automatic and to retain the torque tube, then the Powerglide from a '50-'54 Chevy will be what you want..
Factory applications in later ( '55- up ) models sometimes required adapters for the powerglides and they work for mating up newer Chevy trans also. I'v seen them from time to time on Ebay, but they are made of cast iron
Old 05-22-2011, 11:09 PM
I'd say go with a Muncie M-22. But since you inquired about an automatic, I'd try to source a cast iron Powerglide.
Chevy 292 inline 6 oil pan kreuzn1 Engine 11 03-15-2011 03:11 AM
Chevy Inline 6 solidaxel Engine 6 11-23-2008 10:43 AM
Inline 6 Transmission Fitment oldrodder43 Engine 3 01-06-2008 12:06 PM
chevy inline 6 sdbrooks@cebridge.ne Introduce Yourself 2 01-01-2007 03:14 PM
292 Chevy Inline 6 69GMC Engine 6 02-16-2003 11:31 AM
