What Transmission should I get for my 79 camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2011, 09:25 AM
ProjectPandora's Avatar
I already have a TH350 with a stage 1 shift kit in it and i love the way it shifts but it sucks for highway or cursing. Ive been thinking about a built 700R4 buy i also wanted to see if any one knew if the 6 speed automatic out of the new camaros can work with a old GM 350. any one know?
http://projectpandora.weebly.com
Old 12-04-2011, 02:10 PM
SSedan64's Avatar
The T56 will work but, requires some Mods. I'm not a Stick man so I'll leave that to others. Lots of guys using them in F, G, A bodies etc..
I'd use the 2004R instead of the 700R4.
2004R's the same length as the TH350, will require a TH400, Modded TH350 or an Aftermarket crossmember. TV Cable & Brackets, TCC Lockup Kit.
Old 12-04-2011, 11:25 PM
joshp83's Avatar
owner of Prices Garage
the 700 is 3 in longer than the 350 but the 200r has a diffrent mount location either one is good if built right
91 camaro T5 stock transmission to a 355 SBC logan1 Transmission - Rearend 3 01-08-2011 10:38 AM
85 camaro T5 transmission life? montea Transmission - Rearend 2 08-08-2005 02:47 PM
camaro transmission jo5hi3 Transmission - Rearend 4 11-26-2003 09:49 AM
camaro transmission still not shifting chevcamz28newbie Transmission - Rearend 2 07-20-2003 07:33 AM
Should I buy a T 5 Transmission out of an 87 Camaro 73 Nova Guy Transmission - Rearend 4 03-07-2003 01:39 AM
