what transmission to use???
what transmission would be best for me?
I have access to all 3 Chevy trans. 350 400 and 700R4. I will rebuild any of them.. I will need to buy a torque converter. I will be putting this in a 1947 Plymouth with a stout 355, running around 500 hp. I am going to use this as a cruzer only. no dragging. I plan to take the car on the freeway. Any ideas??? will the bell housing on the 700 bolt up to a pre 87 block? is a 700 strong enough for the application??? Will a stock 700 out of a 3/4 ton truck work? |
700R4 build
Check out the website www.transmissioncenter.net they can hook you up with everything you need to make a 700R4 bulletproof,also have a DVD to walk you thru the rebuild.
| More transmission troubles | chrisflock | Transmission - Rearend | 3 | 08-10-2007 11:07 PM |
| Hotrodders Knowledge Base: Transmission - Rearend | Jon | Transmission - Rearend | 0 | 11-26-2005 06:23 PM |
| transmission oil type. | TVR383 | Transmission - Rearend | 3 | 06-05-2005 09:28 AM |
| Transmission Information. | M&M CUSTOM | Transmission - Rearend | 1 | 08-24-2004 03:15 PM |
| 83 Z28 Transmission - YIKES! | crandaz28 | Transmission - Rearend | 4 | 11-25-2003 07:43 AM |
