what type of cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2013, 02:45 PM
what type of cam
How is the best way to find out what kind and lift the cam is I bought the short block with no specs or infoe on it
Old 01-14-2013, 04:59 PM
BOBCRMAN@aol.com's Avatar
Best way..without specialized tools.. remove it from short block and try to determine the grinder. Lift figure can be determined by measuring base circle. Measure lobe lift times 1.5 gives you the total theoretical valve lift.
Old 01-15-2013, 12:09 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you're not sure if it's a solid or hydraulic, this can help you tell.
Often the manufacturer will mark the cam w/the grind or part number. This may be found under the cam gear or often on the back side of the cam.
If the cam is in the block and heads are off, you can get a close idea of the lift by installing a lifter on an intake lobe and compare the lowest position of the lifter to the highest position, then multiply by the rocker ratio (1.5 is stock). Do both an intake and an exhaust lobe; often they're different (split pattern cam).
The order of the cam lobes on each side is: SBC: front | E - I - I - E - E - I - I - E | rear
To get more precise requires a degree wheel (or at least a timing tape attached to the damper) and a magnetic base dial indicator. This will let you plot the cam for duration and intake/exhaust centerlines, etc.
Click on image for more on making a temporary timing tape:
Dampr w/tape, text:
Other info you might find useful:
Adjust lifters
Cam break in
First start up
HEI distributor/Timing info
Type 2 vs Type 3 Injector 64nailhead Engine 4 12-19-2012 05:03 PM
What type of cam has the least chance of failing? 4speed57 Engine 24 01-29-2010 03:46 PM
GM type 2 or type 3 power steering? dlc1979 Suspension - Brakes - Steering 0 09-22-2008 07:48 PM
What type cam gear speedpro roller cam # CS1071R straydog Engine 0 07-07-2007 08:58 AM
What type of cam should I run in a 7500 rpm 427 clevor? GalaxieRoller Engine 5 07-23-2005 10:05 PM
