What type of differential oil - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2009, 01:10 PM
Absolute beginner
Hello guys,
I need your help.
I have 78 Chevy Monte Carlo with 2,29 rear end (the code on axle is 2 BH 0 66 1), I might be wrong on the ratio. There is also aluminum plate attached to one of the bolts saying "Limited slip differential oil".
Please let me know what type of oil I should use.
I am not in USA and I don't have access to all your oil brands and additives.
Here I can find Mobil, Castrol, Esso and some other world known brands.
Thank you for your help,
Ivo
Old 04-30-2009, 01:46 PM
Originally Posted by rack
Hello guys,
I need your help.
Ivo
The oil will say for Limited Slip on the container, if it doesn't, it isn't.
- Mobile 1 Synthetic LS 75W-90
- ESSO LS 80W-90 or LSA 85W-90
- Castrol Part Number 3015 in 80W-90
- You might also look for Silkolene BOA90LS in your part of Europe
These are all Limited Slip rated oils, however some people report issues with Mobil 1 in GM Posi-Traction. A solution that would help and also make it so you can brew your own LS oil from regular hypoid oil is the GM LS additive part number 1052358 if you can find it.
Bogie
Old 05-01-2009, 01:09 AM
Absolute beginner
Thank you very much Bogie,
You helped me a lot.
Best regards,
Ivo
Old 05-01-2009, 06:38 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I had a chatter problem with Mobil 1 gear oil in a Ford 8 inch differential posi. The posi was a fresh rebuild with posi plates soaked in Mobil oil
I added the Ford posi lube additive , the chatter problem stopped
Old 05-01-2009, 08:08 AM
302 Z28's Avatar
I had the same problem as Crosley, but with Royal Purple synthetic gear oil, added a bottle of Ford additive and it went away. In spite of what the advertisement says on the bottle of oil you may still have to add the Ford product.
Vince
Old 05-02-2009, 01:31 AM
Absolute beginner
Hi Guys,
Thank you for responses.
Do you mean that no matter what oil I use I would be better of with GM additive?
I find it on the Internet for around $10, it is not a big deal, just have to get it here
Regards,
Ivo
Old 05-02-2009, 07:53 AM
302 Z28's Avatar
You would just have to try it with the oil you are using and see if the additive is needed. Note: don't get any of that stuff on you, it stinks to high heaven .
Vince
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 07:39 AM
Valce cover Oil leak problem / PCV system question hotrodf1 Engine 7 05-01-2007 02:44 PM
A little humor Kevin45 Hotrodders' Lounge 8 10-21-2004 12:47 PM
what type oil?? savman1 Engine 5 05-04-2004 09:51 AM
