Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - what type of grease to use on new distributor points?
Old 04-27-2013, 02:58 AM
techron techron is offline
Originally Posted by snkbyt View Post
Man...why are you using points??? Check out the Pertronixs. use you distributor and it is a direct replacement. Get rid of the points...
So true, but the OP asked about points. In the old days all points sets were replaced at the same time with condensors, The points always came with a little packet of grease, it always looked like vasaline. I always applied it to the dist. cam VERY SPARINGLY so the nylon rubbing block on the points would not wear too fast and change the dwell. On single points (and dual points on Vettes) as the rubbing block on those old skool cars wears the Dwell and timing changes. These were 60s Hi Perf cars. I Learned how to set single and dual points. Now I also run Pertronix in my pantera and 64 vette resto mod. I also run a MSD in those cars.
