Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - what type of grease to use on new distributor points?
Old 04-27-2013, 09:11 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
you are 40 years behind the times
Originally Posted by cal1320 View Post
What he said. And apply it so as the block wears, it drags more grease into the dist cam.
And nothing wrong with points. They are dependable (with normal dwell adjustment), and can be found anywhere. When that Pertronix module or MSD fails, you're stuck.
points not only are less reliable than modern electronics,they cost you HP,your plugs dont last as long,the engine is harder to start,bigger cams need a bigger spark especially at idle,,,,
I wont bother posting anymore obvious reasons to not use points,,,
