-   -   what type of grease to use on new distributor points? (http://www.hotrodders.com/forum/what-type-grease-use-new-distributor-points-232259.html)
adam83 04-26-2013 08:38 PM
my new points (for a chrysler 400) I bought did not come with a little packet of grease. The auto parts guy didn't know what kind to use either. I want to putthe points on now and don't want to wait for an online order.. what would an autozone type store have in stock?
scholman 04-26-2013 08:44 PM
Use Vaseline on the back side of the rubbing block
68NovaSS 04-26-2013 09:31 PM
You can also buy a tube of Dielectric grease at any auto parts store.
snkbyt 04-26-2013 10:33 PM
Man...why are you using points??? Check out the Pertronixs. use you distributor and it is a direct replacement. Get rid of the points...:)
techron 04-27-2013 02:58 AM
So true, but the OP asked about points. In the old days all points sets were replaced at the same time with condensors, The points always came with a little packet of grease, it always looked like vasaline. I always applied it to the dist. cam VERY SPARINGLY so the nylon rubbing block on the points would not wear too fast and change the dwell. On single points (and dual points on Vettes) as the rubbing block on those old skool cars wears the Dwell and timing changes. These were 60s Hi Perf cars. I Learned how to set single and dual points. Now I also run Pertronix in my pantera and 64 vette resto mod. I also run a MSD in those cars.
cal1320 04-27-2013 07:17 AM
What he said. And apply it so as the block wears, it drags more grease into the dist cam.
And nothing wrong with points. They are dependable (with normal dwell adjustment), and can be found anywhere. When that Pertronix module or MSD fails, you're stuck.
vinniekq2 04-27-2013 10:11 AM
you are 40 years behind the times
points not only are less reliable than modern electronics,they cost you HP,your plugs dont last as long,the engine is harder to start,bigger cams need a bigger spark especially at idle,,,,
I wont bother posting anymore obvious reasons to not use points,,,
