what type of grease to use on new distributor points? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2013, 07:38 PM
adam83's Avatar
my new points (for a chrysler 400) I bought did not come with a little packet of grease. The auto parts guy didn't know what kind to use either. I want to putthe points on now and don't want to wait for an online order.. what would an autozone type store have in stock?
Old 04-26-2013, 07:44 PM
Use Vaseline on the back side of the rubbing block
Old 04-26-2013, 08:31 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You can also buy a tube of Dielectric grease at any auto parts store.
Semper Fi
Old 04-26-2013, 09:33 PM
snkbyt's Avatar
ASE Master
Last journal entry: 52 Chevy for sale
Man...why are you using points??? Check out the Pertronixs. use you distributor and it is a direct replacement. Get rid of the points...
Old 04-27-2013, 01:58 AM
So true, but the OP asked about points. In the old days all points sets were replaced at the same time with condensors, The points always came with a little packet of grease, it always looked like vasaline. I always applied it to the dist. cam VERY SPARINGLY so the nylon rubbing block on the points would not wear too fast and change the dwell. On single points (and dual points on Vettes) as the rubbing block on those old skool cars wears the Dwell and timing changes. These were 60s Hi Perf cars. I Learned how to set single and dual points. Now I also run Pertronix in my pantera and 64 vette resto mod. I also run a MSD in those cars.
Old 04-27-2013, 06:17 AM
cal1320's Avatar
What he said. And apply it so as the block wears, it drags more grease into the dist cam.
And nothing wrong with points. They are dependable (with normal dwell adjustment), and can be found anywhere. When that Pertronix module or MSD fails, you're stuck.
Old 04-27-2013, 09:11 AM
vinniekq2's Avatar
you are 40 years behind the times
points not only are less reliable than modern electronics,they cost you HP,your plugs dont last as long,the engine is harder to start,bigger cams need a bigger spark especially at idle,,,,
I wont bother posting anymore obvious reasons to not use points,,,
what type of laundry soap works the best to remove grease, oil and dirt. onebadmerc Hotrodders' Lounge 25 02-16-2013 11:30 AM
distributor with points zoey2 Electrical 5 03-27-2012 02:53 PM
If the condenser is bad in a points type dist.would the car run Mr. Wormy Engine 6 08-12-2006 06:23 AM
points type coil wiring Mr. Wormy Engine 2 04-06-2006 07:23 AM
distributor-oil?-grease Slickriffs Engine 2 09-01-2005 12:18 PM
