Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What type of Master Cylinder
Old 01-15-2006, 10:07 AM
johnnymopar's Avatar
johnnymopar johnnymopar is offline
Love your nails! You must be a Libra
m/c's for a disc/drum combo have a dual reservoir where the disc reservoir is larger than the drum reservoir because the front calipers have a larger fluid capacity. the check valves you are talking about are usually 10# on the disc line and 2# on the rear lines. this will allow the rear brakes to activate before engaging the front brakes.
hope this helps.
"Well done is better than well said." - Benjamin Franklin (1706-1790)
