what type of paint for frames suspension? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2008, 07:00 AM
what type of paint for frames and suspension?
what type of paint is good for frames and suspension parts? i will use black epoxy and then top coat it but i dont know with type other than it will be single stage. i want something with gloss that will hold up, also how much will be needed? its a short box truck and i want to paint the frame and the control arms and rearend, and maybe the bottom of the cab and box too, thanks
Old 07-31-2008, 07:17 AM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
Some day I'm going to try some of this "Aluthane" stuff to see if the guy's just 'blowing smoke'. That kind of experiment will be on a beater truck, though.
Based on what I've read here I'll be using some enamel with hardener over epoxy for the frame I want to look good for a long time. I'm sure you'll get some advice from someone here who actually has a clue, though.
Old 07-31-2008, 08:03 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
2 wet coats of epoxy primer and I use SEM Rust Shield as a top coat..2 coats of that...and order the activator with it..Get a gallon and quart of activator as painting a chassis and all the pieces takes an amazing amount of paint..
Sam
Old 07-31-2008, 09:09 AM
Check into por15, its glossy and durable
Old 07-31-2008, 03:40 PM
adtkart@aol.com
If you check the threads with that stuff discussed, you will find that none of the professional painters here will advise the use of that product. That should tell you something!
Aaron
Old 07-31-2008, 04:13 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
My frame is actually coated with eastwoods rust encapsulator. It seems to be holding up OK as far as rust (I did not do it), but it definitely needs to be topcaoted with something (maybe SS).
It is that horrible red primer color. Looks really dull and getting worse (no UV protection). The suspension, underside of everything (including drivetrain and exhaust) is coated with it.
The exhaust that was painted with it is burning off of course.
This is a pic of when I first brought it home. It is a lot duller now.
I plan on using SPIs bedliner on the underside of the entire body eventually.
I am just now starting on the body work. I am a total amateur.
Old 07-31-2008, 07:53 PM
i have a bunch of POR 15 but i am kinda scared of using it now because i hear alot of people have it peel off a few years later or chip and get the rust to spread under it. I have my truck striped down except the cab is still on the frame so i am thinking of renting a big compressor and sand blasting it now, i just dont want to have gone through all this work and it only last a few years, from what i have used of POR 15, i do like it, i am just worried of it coming off down the road, i think epoxy and a ss black over top is what i will do.
Old 07-31-2008, 08:16 PM
zero rust, is a great product better than POR15 IMO
Old 07-31-2008, 10:12 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I tried "Endura" which is a 2K Urethane.
Goes on glossy, is available in a multitude of colors, and is supposed to be hard as nails. Almost legendary stuff in these parts,
They paint tractor-trailer units, drilling rigs, etc with it here in Alberta (where they are headquartered)
I guess I should add the disclaimer that this truck hasn't left the garage yet, so I can't offer up any "personal experiences" regarding durability yet.
Old 07-31-2008, 10:14 PM
Brian_B's Avatar
Lost in the 50s!
That is not bright enough.
I am having trouble seeing the suspension parts.
Old 07-31-2008, 10:17 PM
66GMC's Avatar
What can I say, Brian ... I'm a partsman. That's the way it looked in the "ez-finder" sales guide.
Old 08-01-2008, 12:22 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
My vote, powder coat.
These are now on my '74 C-10. Did 'em myself.
I could have painted them, but I already had the equipment. Powder vs. paint, the actual powder is cheaper. Equipment, well...is a little more.
Results are nice, but hard to exactly match a 'paint' color.
Name:	powdered arms etc.JPG
ID:	31574   Click image for larger version
Name:	powdered arms etc 2.JPG
ID:	31575   Click image for larger version
Old 08-01-2008, 06:38 AM
pics look great guys, what is the cost of a gallon of the undura?
What Type Of Paint? daworz Body - Exterior 1 03-30-2007 10:29 PM
Cost of paint Job - complete do it your self job at home Warrant Body - Exterior 74 07-13-2006 09:31 PM
This is interesting. Temporary peel off paint. kenseth17 Body - Exterior 5 08-11-2005 09:41 PM
Looking to paint my car with OEM quality finish. Have some Questions Gro Harlem Body - Exterior 12 01-15-2005 06:31 AM
