What type a pistons came in a 74' 350 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2010, 08:46 AM
I have a 74 Nova SS with a 350. Would the pistons be dished or flat tops? Being the smog era guessing dished but seeing if anyone knows.
Old 07-26-2010, 09:14 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Should be dished . 8.1 or 8.5 to 1 compression . Just getting the engine bored to cleanup and putting the correct flat top pistons and a good valve job and all new bearings (cam brngs also) and freeze plugs will give you a great running engine for an everyday driver with a stock cam . I have done this before and it gives about a 50% torque increase over stock just going by the improved performance . If you just job out the machine work and do all the dis and re assembly yourself you should be able to do it all for less than $800.00
Old 07-26-2010, 09:28 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I agree- dished if OEM.
A common piston was the 0.080", ~11cc dish volume, gives a CR of 8.5:1 w/a std. bore 350; 0.015" shim gasket; piston 0.025" in the hole; 76cc combustion chamber volume.
Old 07-26-2010, 09:44 AM
I'm looking to buy Summit Racing 64 cc Iron heads with 2.02 valves that sell for $615 a set. What kind of compression will i see from these heads using my stock pistons? The motor runs good as is and does not smoke so a rebuild is not necessary.
Old 07-26-2010, 09:56 AM
About 9.1 with a factory crown to deck clearance of .025 inch and a gasket of .025 inch.
Bogie
Old 07-27-2010, 09:13 AM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Wow cobalt , You are so much more up on this stuff than I am that I feel like a first grader sitting in on a senior class on physics . I always look for your posts 'cause I am sure I'll learn something .
Old 07-27-2010, 09:53 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That is kind of you, Big. I suspect that after just a bit of being back into it, much will come back to you as well as picking up more info from the place where you left off last time around.
But, thanks just the same.
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
350 chevy help joesnova2 Engine 7 11-08-2009 05:46 AM
307 Chevy with 283 Chevy Pistons?? sbc307 Engine 4 10-31-2009 09:26 PM
Ford 351 C vs chevy 350 eric32 Engine 3 09-18-2009 04:42 PM
is this Pontiac or Chevy 350 GMR Engine 8 03-31-2009 06:28 AM
