what type of primer over body filler - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2012, 12:08 PM
I want to know can u use a filler primer to fill in miner scratchs on body filler. And should i seal it after our just leave it. Im thinking of using epoxy/filler primer in one.
Old 04-23-2012, 01:35 PM
What kind of scratches are we talking about? Personally, I don't want to "ask" my primer to do fill more than 180, or 120 grit scratches at the most.
Old 04-23-2012, 01:45 PM
180 grit. I start with 80 grit then work to 180 or 220
Old 04-23-2012, 01:48 PM
In the past I've used spot and glazing putty but some times its a pain i like something a little easier
Old 04-23-2012, 01:49 PM
Urethane primer is what is commonly used for surfacing body work (blocking) and all I have used for years since the lacquer days. But some will use an epoxy or even an "iso free" 2K urethane like product.
Most any quality urethane primer is going to fill 180 grit scratches without any problem what so ever.
Old 04-23-2012, 02:10 PM
Old 04-24-2012, 12:18 AM
I am not sure I understand what you mean. Urethane primer doesn't replace polyester putty. Polyester primer maybe, but not urethane.
Old 04-24-2012, 04:54 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Some of those "epoxy/filler" primers are known to shrink a lot, so if you
do use one, allow a lot of time afterwards for that.
I like to sit them out in the sun a couple of days before sanding.
can I put body filler over primer? lamothe1 Body - Exterior 12 01-05-2012 06:07 AM
body work primer type Carlos9 Body - Exterior 4 10-22-2010 10:18 AM
Urethane primer and body filler Lator_Gator Body - Exterior 23 01-08-2007 02:15 PM
Body filler over the primer? Skipr Body - Exterior 3 11-22-2005 05:19 AM
Body Filler Over Epoxy primer lowlife_caddy Body - Exterior 4 08-26-2004 04:14 AM
