What type of primer/sealer and paint? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2012, 03:44 PM
Guys,
I am getting ready to prime my 69 AMX after stripping it to bare metal and hanging some new sheet metal. With so many options on the market, I am wondering what I should use to prime/seal it. I am planning on doing the bodywork over the primer/sealer I apply. I am doing the bottom of the car as well as the top. A friend recommended Transtar 2K Epoxy primer sealer. Any thoughts or experience with this product? I used it on the frame of my 69 corvette and found it worked nicely for that.
Also not entirely clear on what I am using for the topcoat and would appreciate any suggestions for that as well. I seem to remember someone on another post recommended something different for the bottom of the car than for the top, for the obvious reason of not being able to sand the bottom.
Thanks for the help.
Mike
Old 05-04-2012, 10:10 PM
gonzo08383's Avatar
Last journal entry: brakes
i'd use a self etching primer first then epoxy primer/sealer. urethane primer after that. the manager of dupont by my house suggested that. top coat i'd use an acrylic 1 step base/clear system if you're on a budget. i used it on my camaro. worked pretty good. its only about 150 worth of paint for the whole car and you can sand it down and spray clear on top if you want. as far as chassis painting i'd use primer sealer then cover it with rhino liner. buddy of mine did that with his car, looks pretty sweet but i'm biased to the flat black look. it hides imperfections well and blends in the surrounding car parts. pleasing to the eye and what not.
Old 05-05-2012, 07:37 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
I would go here: http://www.southernpolyurethanes.com/ and look around.
Old 05-07-2012, 10:53 AM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
SPI as recommended above.. Best bang for your buck in my opinion.. Top shelf products at very affordable prices. Customer service that cant be beat..
You can speak directly with the owner of the compny. he will assist you like no one else.. Ask painters who use the products and you will soon find why everyone raves about themm
go here http://www.spiuserforum.com/forum.php
You wont regret it!!!
Old 05-07-2012, 11:01 AM
cyclopsblown34's Avatar
Colorsanding painter
I'd get your metalwork done with 80 grit and then epoxy prime it. Tehre's no need for the etching primer and then epoxy. I've used the Transtar 2K Kwik Prime on bare metal and it works really well, I have no experience with their epoxy. I have used the Southern Polyurethanes epoxy and believe it is the best I've sprayed. Their Universal Clear is hands down the best and easiest I've ever sprayed.
HOK Ko-Seal Primer Sealer vs Epoxy Primer 67Elcamino Body - Exterior 0 02-02-2012 11:34 PM
type of gasket sealer to use stoney 81ta Engine 8 07-25-2010 06:56 PM
lacqer primer over sealer primer jake henderson Body - Exterior 20 08-24-2008 09:12 AM
Epoxy Sealer-Primer With 2K Build Primer on top kilgorq Body - Exterior 4 04-29-2008 04:30 PM
Epoxy sealer/seam sealer/paint equip Blackdog Body - Exterior 17 10-21-2004 11:19 PM
