What type of Sewing machine? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2009, 11:19 PM
I've been eyeing osme of them up on ebay. What recommendations for auto upholstery?
Old 06-16-2009, 07:09 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Check out this thread: CLICK HERE The question is, what are you going to use it for? Are you planning on doing one interior or a lot of interiors. If you only want to do one interior, find a reasonably priced compound feed walking foot machine. Compound feed means it has a combination of drop feed, using a feed dog, and needle feed, which means the needle helps push the work forward in conjunction with the feed dog. What you're looking for is a Singer 111W or one of its many clones.
Old 06-23-2009, 08:12 AM
sirstude's Avatar
New Member
Dan,
I read these threads all the time, but haven't had anything to add at this point. I picked up a Singer 78-1 a couple of years ago, and have played with it and found that it definately leaves some to be desired. Mosty, it is a walking foot, but not a compound walking foot, and I fight it trying to get an even stitch. Anyway, I found a new home for that machine and have now found a Consew 226 that you seem to like a lot. Any thing that I should know about that machine. The guy that I am getting it from uses Consew 206's and picked this one up. He has checked it out and runs good, so i guess I am just looking for any tips I could use.
Thanks
Doug
Ps. I am slowly working my way though the Foley-Belsaw home upholstery course.
Old 06-23-2009, 08:59 AM
Wiki Edits: 22
Hi Doug: Nothing special about the 226, it's just a good solid compound walking foot machine. I like mine because it was given to me for nothing! What I like about it is that the bobbin is on the right side of the needle under a sliding plate, and you don't have to take the bobbin case out to replace a bobbin. That's just a personal preference.
One thing I can tell you is to keep it oiled properly, and that includes the areas under the cover plate at the end of the machine head. Do you see the two oily looking wicks sticking out of the ends of some of the pieces? Keep those oiled along with the rest of the machine and it will last you a long time. There are other places inside that cover that also need to be oiled, but are not visible in this picture.
Old 06-24-2009, 08:28 AM
sirstude's Avatar
New Member
Thanks for the info Dan, it will help when I pick this up and start playing with it.
Doug
ps, keep the tutorials coming, very good read and helpful.
Old 06-24-2009, 07:45 PM
cacsmret's Avatar
Last journal entry: Another year gone by...
Consew 166r?
I see a Consew 166r available on craigslist, however, I cannot find any info on the net about this machine. Is this a desirable machine for auto upholstery?
Old 06-24-2009, 09:17 PM
Wiki Edits: 22
As far as I know, Consew lists no such machine with that number. There is a 106R, however. This is a lighter weight industrial machine, and has only a 1/2" presser height lift. I'm not sure if it is a compound walking foot machine, but I think it is just needle feed. Here is a link to a manual for that machine: CLICK HERE If that's what the machine is on Craig's List, it would not be a the best choice for auto upholstery.
Old 06-25-2009, 05:48 AM
There is a parts list for the 166R at
http://www.micsew.com/consew/consew_disk1/166.PDF
Not much information, but page 14 of the parts list, item 200 is a "Walking Foot", so this machine might be suitable for heavy work. I can't find anything else about the 166R, maybe someone who has one will chime in.
Ed
Old 06-25-2009, 07:19 AM
Wiki Edits: 22
Oops, my bad. The list of Consew machines I have doesn't list 166 or 167 as one of their model numbers, but there obviously is such a machine. It appears that this machine might be a predecessor of the Consew 206. It has a bobbin case that is vertical instead of horizontal, and you need to remove the bobbin case to change bobbins. It also uses a standard industrial needle size of 135X17. If it is close to a 206 in specifications, it would work fine for auto upholstery. The listing in Seattle Craig's list has expired, so no way to look at it there.
Old 07-07-2009, 03:43 PM
Microsoft Paint's Avatar
Can a overlock sewing machine be used for interior stuff?
Old 07-07-2009, 04:00 PM
Wiki Edits: 22
Overlock machines stitch, trim, and overcast seams as they sew, which would not have many practical applications in auto upholstery. This would be great sewing clothing, etc, but I'm afraid the machine would not be heavy enough to do seat covers with sew foam.
Old 07-27-2009, 04:35 PM
Auto Upholstery
Hi, my fiance and I just bought a 74 super beetle and are restoring it. I have a 67 singer machine my mom got me and it works get. Anyways I am going to be redoing the seats and have bought the fabrics which is like a pleather with a fuzzy backing. Anyone have any idea regarding the thread to use for this. The book that came with the machine says heavy, but I am also worried about tearing at the seam. Any suggestions would be appreciated..Thanks Dale
Old 07-27-2009, 06:59 PM
Wiki Edits: 22
Use #92 polyester thread. Standard thread is size 69 nylon. #92 is half again thicker, and slightly stronger than the 69 nylon. Polyester stands up better to UV rays. To keep from cutting the fabric, set your stitch length to 5 or 6. Also, make sure the tensions are adjusted correctly. You can have stitches that look right, but if both tensions are too tight you can still cut the fabric.
Old 07-28-2009, 06:41 AM
Crosley's Avatar
Wiki Edits: 1659
We bought my wife a Nakajima 280L machine about 20+ years ago.. still works well. it will sew your fingers together if you are not careful
Old 07-28-2009, 07:46 PM
Hey Dan do you think a Kenmore Zig Zag machine would be able to handle light interior stuff like door panels or stretching it a bit.... seats.
finally buying a sewing machine PUREAUDIO Interior 47 02-24-2010 07:13 AM
help on buying a sewing machine!!!!! NEW INTERIORS Interior 41 09-28-2007 03:23 PM
DOH! Sewing Machine Revelation! - well, at least to me... Dusty82 Interior 17 08-29-2007 12:10 AM
Regular Sewing Machine for Auto Upholstery?? Jim Weeks Interior 47 04-24-2007 03:09 PM
Are machine shops dying off? Jmark Engine 32 09-12-2003 05:36 PM
