What type of suspension in Forklift? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2013, 06:35 AM
New Member
It is reality to put a suspension on a fork lift yet to what indicate. Why would any one need a machine that is intended to grab stuff, and need one that hang & inclined in light of the fact that it grabbed a substantial burden?
Old 05-31-2013, 07:10 AM
Wiki Edits: 27
farm lift.
Most of the Farm home made forklifts start with an old 1 1/2 dually farm truck. Shorten the frame, turn the rear end upside down, mocify the seating and steering, We have a home made Farm forklift made by a guy that had a shop down the road. He started with a 57 chevy 1/2 ton, later 350, 350, and a one ton rear end, The original front suspension uses the stock springs and shocks, redesigned steering linkage and seat so I sit facing the lift and the rear end is turned upside down,mounted solid. The "factory" forklift with side shift mast is mounted on the Frame tight to the rear axle. It has a very short wheelbase, is scarry to drive on the road. most of the time I drive with my foot on the brake. The Toyota warehouse forklift has no suspension, but the rear steer "front" axle has a center pivot. The long reach construction lift we use for stacking Hay has 4 wheel steer or 2 wheel steer, hydralic cylinders for a "suspension" so I can level the load on sloping ground.
Rear suspension type? S10xGN Suspension - Brakes - Steering 0 09-26-2012 06:26 AM
What type of suspension to run my oldcar Hotrodding Basics 5 04-21-2010 03:42 PM
forklift experts mitmaks General Rodding Tech 3 01-21-2009 10:00 PM
what type of paint for frames suspension? dmcphee07Si Body - Exterior 12 08-01-2008 06:38 AM
Front Mustang type Suspension for 38 Chevy roys63 Suspension - Brakes - Steering 6 05-04-2006 12:45 PM
