What type of trans fluid is best to use? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2014, 07:08 PM
Preparing to install my new converter into the transmission and put the engine back in this weekend. Coan recommends either DEX/MERC III type F or FA or Amsoil synthetic universal transmission fluid. Does anyone have a recommendation which would be better for a street driven car that probably won't see track use? Motor is a blown BBC and the converter has a stall speed of 3800 rpm and is a ten inch size. Coan suggested using the synthetic fluid for street performance but the stuff is almost $12.00 per quart at my local supplier. Is it worth the cost? Thanks for any replies.
Joe
Old 07-21-2014, 09:11 PM
Banned
Dont switch to type f from dextron unless you want to rebuild that tranny.Type f will swell all the rubbers. I would just keep fresh regular atf in it.
Old 07-22-2014, 07:35 PM
Cape Cod Bob's Avatar
I know you know this but I will say it anyway. Be sure to put some in the converter first.
Old 07-22-2014, 09:01 PM
Proud LOSER
Behind a big HP blown application do some reading on John Deere "Hy gard" fluid... cut with a litre of conventional fluid to add color so you can see it (hygard is clear). Works very well and is fairly inexpensive.... I'm about to use it in my TH400 behind a single turbo 383.
Trans fluid vs power steering fluid? wave1957 Hotrodding Basics 9 06-28-2014 02:02 AM
Synthetic Trans Fluid Mixed With Regular Trans Fluid smokey626 Transmission - Rearend 1 06-14-2009 01:33 PM
Best Type F transmission fluid out there? 84Z Transmission - Rearend 3 05-11-2006 08:43 AM
th-350 fluid type john r Transmission - Rearend 3 08-15-2003 07:10 AM
TYPE F FLUID IN A GM TRANS??? ss crazy Transmission - Rearend 10 01-15-2003 07:22 AM
