Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What type of wire to be used in automatic transmission oil
Old 07-04-2012, 05:35 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
I would think a GXL or SXL wire would resist oil
Shrink tube needs to be polyolefin material. I use dual wall with adhesive inside it that flows out under heat.
Trans oil will soften up the budget shrink tube, been there.
or purchase a fresh replacement wire harness . Rostra is a quality brand harness
