What type of wire to be used in automatic transmission oil - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2012, 11:59 PM
I'm on the final stage of rebuilding my 700-R4. My lockup wiring is very brittle, bending it about 90 degrees will cause the sheathing to break. I am wondering what type of wire is recommended for use inside the transmission. Is heatshrink OK to use in transmission oil?
Also I have a temp switch currently in my trans. From what I have read if the fluid gets above a certain temperature the switch will close and cause the torque converter to lockup in an attemp to cool the transmission down. Should I keep this in the circuit or is it OK to bypass? FWIW, TCC will be controlled via ECU.
Old 07-04-2012, 06:35 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I would think a GXL or SXL wire would resist oil
Shrink tube needs to be polyolefin material. I use dual wall with adhesive inside it that flows out under heat.
Trans oil will soften up the budget shrink tube, been there.
or purchase a fresh replacement wire harness . Rostra is a quality brand harness
Old 07-04-2012, 06:39 PM
If I could get a new harness I would go that route as the plastic conduit is broken in many places. Any idea if they make a harness for a 1989 Caprice 5.7L? I have seen some delco ones but there is no information on what they are for and ythe pictures are crappy. I would need the one that has 4th gear switch going to the ecu with the temp switch. And then 2 wires for the lockup solenoid itself.
Old 07-05-2012, 03:52 PM
SSedan64's Avatar
This one looks to have only the 4th gear & Temp connectors.
700R4 TCC Lockup Solenoid With Harness 700R4 Converter Lockup Solenoid
https://www.wittrans.com/Schematic.a...R4&Schematic=6
Local Trans Shop may also have the one you need.
Old 07-06-2012, 01:23 AM
Thanks SS, I found this one as well:
AC Delco 24235642 AC Delco 24235642
. According to the picture it looks like the correct harness.
1996 chevy z 71 which automatic transmission type? rudywilhitejr Transmission - Rearend 2 01-25-2012 10:01 PM
What Type Of Fluid Or Oil Does A Standard Transmission Use??? majeic Transmission - Rearend 8 05-05-2010 11:59 AM
Automatic Transmission Fluid Type A jimra1944 Transmission - Rearend 2 11-21-2005 03:31 AM
transmission oil type. TVR383 Transmission - Rearend 3 06-05-2005 10:28 AM
automatic transmission help lance4k Transmission - Rearend 5 03-18-2005 06:33 PM
