What type of wood for headliner bows? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2008, 10:39 AM
Last journal entry: Bringing home the 401 Nailhead
The headliner bows on my 39 Willys are small rods. Reasearching the knowledge base I have read not to use them. So what kind of wood would be best for new bows? I was thinking of two pieces of 3/4 plywood glued together. This would give me 1 1/2 wide bows.
Old 01-30-2008, 01:39 PM
DanTwoLakes's Avatar
Wiki Edits: 22
I assume this is a coupe or a 2 door sedan. Are you putting in a "hard" headliner? If so, yes, don't use the metal bows. You don't want to use solid wood because it could warp. You don't need two pieces of 3/4" plywood, that's overkill. One piece will do, but use hardwood plywood for better holding power when you screw on the luan headliner base. After you put the new wooden bows in side to side, connect the bows front to back to make a grid to hold up your headliner base. Look at the '47 Ford in my project journal. The wooden gridwork was so strong I could literally hang from it. I screw metal "T" brackets to the ends of the hardwood plywood bows and attach the "T" brackets to the sheet metal around the perimeter of the roof. You can also glass them in or use other fillers if you prefer,... anything to hold them solidly.
34 Chevy wood replacement paulf55c Introduce Yourself 1 11-28-2007 04:09 PM
29 chevy coupe wood structure marblemanor Body - Exterior 4 10-22-2007 08:04 AM
Installing a New Wood Bed Kit sleepyd Body - Exterior 2 10-18-2007 07:49 AM
Bonding wood to fiberglasas mar10 Body - Exterior 25 07-24-2005 05:11 PM
Wood eye? Madd Syntst Body - Exterior 7 12-24-2004 03:22 AM
