Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - what to upgrade on a 5.7
Old 03-11-2006, 12:09 AM
Kevin Varnes Kevin Varnes is offline
It might make life easier on you to run a carb and vacuum advance distributor. I'm not overly familiar with the injection setup on the engine you have. If you want to keep the EFI you'll need a higher pressure fuel pump, return lines to the tank, all of the electronics from the donor vehicle, etc.
