Originally Posted by Kevin Varnes
It might make life easier on you to run a carb and vacuum advance distributor. I'm not overly familiar with the injection setup on the engine you have. If you want to keep the EFI you'll need a higher pressure fuel pump, return lines to the tank, all of the electronics from the donor vehicle, etc.
The main reason for the swap is the TBI, FI is is almost a necessity off road, there are times when my vehicle is almost vertical, the carbs don't cut it then. I am well aware of what needs to be changes to get the SBC in the jeep, its almost done and about as easy a swap as you could do. but is there anything that i would want to up grade to sneak a bit more performance out of it. i have to replace the TBI unit, should i stay with the stock unit or upgrade it?
