what to use for a frame? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2011, 01:29 PM
hey guys i am doing a rod project and am throwing around the idea of building a frame wiht the suicide springer front end, and i was just wondering if there is any frame that you guys like to use? or just build one?
Old 11-21-2011, 02:21 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Moving to the suspension forum.
Semper Fi
Old 11-21-2011, 03:00 PM
35terraplane's Avatar
Frame
What body are you using?
Bob
Old 11-21-2011, 03:59 PM
Frame Upgrade
Use an "Art Morrison" frame. Its a great product and you wont have the headache of building it. "Art Morrison.com
JohnM
Old 11-21-2011, 06:47 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
...... i finally got a body off of a guy comeing back from a swap meet at a gas station haha it is old model t touring tub and a front cowl off of what i belive is a late model t.......
A Model T is very narrow, any frame made after 1928 will be too wide.
So you are almost forced to either start with a stock Model T frame or build a frame frome scratch.
Speedway Motors sells reasonably priced frames, kits, etc. If you are a beginner that's the route I would recommend. http://www.speedwaymotors.com/Tradit...ame,24798.html
When I built my '27 Roadster Pickup I started with aftermarket '32 rails, just bare stamped rails, and made everything except the front '32 crossmember, that I narrowed radically, from scratch. It was a lot of work, but very rewarding. I would not recommend building your on frame unless you have access to the materials (tubing, pipe and plate) and the tools (cutting torch, welder, grinder, drill press, jack stands, clamps, engine hoist, etc.).
Good luck
Old 11-21-2011, 06:54 PM
life is a temporary assignment
If your doing a suicide front end just build it.... You can do a simple t-bucket style frame.. One of the easies frames there is to build and can just about build any body you want on it... Build it you will be way ahead of the game...
Old 11-21-2011, 08:51 PM
Wiki Edits: 31
Yep. just build a jig of some sort, and clamp the rail so it doesent warp..
2x3 or 2x4 11 ga will be sufficent
Old 11-22-2011, 09:24 AM
I do have those tools not a plasma but a torch set and i have some weding skills. i am use a old touring tub and old model t cowl, i want that old looking style and i think building it will be the best way. what kind of jig should i build? i was thinking like out of 2x4 wood and maybe some 4x4s? any ideas? and this is my fist rod so this is all knew still. thanks again guys!
Old 11-22-2011, 10:16 AM
You don't need a jig to build a t-style frame... But if you do want to build a jig.. This is a cheap one I built when I did my 41 willys frame..It worked out great and I still have it picked up if I ever want to do another one..
Making A Willys Frame !!
It may give you some idea's.. Good luck..
There's a lot of people here to help if needed..Take your time and it will all work out..
Old 11-22-2011, 01:00 PM
i am sure as this project goes on i will be asking alot more questions haha and i like that idea for a jig. alot more light weight and cheaper then what i was thinking about haha and i will try tonight to get some pictures of the body up on here also so you guys can see what i am working with
Old 11-22-2011, 02:02 PM
Wiki Edits: 27
t bucket plans
There is a lot of t bucket info in the WIKI, here one titled free t bucket plans, I built a couple chassis using the CCr plans for a bucket. You migh want to add a few inches for a tub body. check new interiors build of his c cab.
Old 11-22-2011, 02:15 PM
Wiki Edits: 31
My jig is a bit diffrent than Randy's. It just holds the peices square and tight for welding. still need flipped ( and another set of holes ) for the opposite side.. I did my first frame without a jig and it got a bit off and, altho it could have been saved, it was easier to start over. I also built it to the correct dimensions.. The yellow rustoleum brightens things up for welding. the orange blocks were for effect. they don't do much
Old 11-22-2011, 03:05 PM
You can build a frame without a jig.. I have done a few on the ground... Just have to watch it as your welding things up.. and skip around when welding...Here's a new build I'm doing with no jig..
Building A Homemade C-cab !!!
Old 11-22-2011, 06:04 PM
Wiki Edits: 27
horse shoe nails
I keep a box of horse shoe nails in my welding box, if things start to warp when tacking. Cut the weld and use the miniature wedge to realign things and you can nip off the extra part and weld over them.
Old 11-25-2011, 10:24 AM
thats a good idea, stuff does tend to wrap on me haha a
1950 truck frame swap to 1980's chevy frame 1950truck Suspension - Brakes - Steering 28 05-29-2017 12:23 AM
TIme for frame work.. Adding new half frame PureC4 Suspension - Brakes - Steering 1 08-20-2011 12:43 PM
1967 Buick Lesabre convertible Frame or compatible frame wash64864 Body - Exterior 1 12-07-2010 09:13 PM
Subing Nova frame into a 1957 chevy truck frame crshields90 Suspension - Brakes - Steering 1 02-02-2008 09:15 PM
replacing a front unibody frame with a tube frame ? (bit long) lowROLLERchevy General Rodding Tech 5 04-06-2007 09:49 PM
