What to use to glue in window
Guy's what do you use to glue the side windows to the bottom channel that hooks to the regulator.
Thanks Rick |
glue
I've used both.But if you dont use windsheild glass primer with the urathane glue sometimes it'll let loose.
Thanks guys, where would I get glass primer?
Get the rubber tape at your auto local window shop. They usually give you several feet for free, especially if they are the guys who cut your glass. It is designed for just the right amount of hold and works every time. Urethane is great but it can grab hold and NEVER let go! The tape comes in a couple of thicknesses so take your window and channel in and they will give you the right stuff.
Sorry about pulling up an old post, but I couldn't find the information I was looking for. Maybe didn't look in the right place.
Anyway, I got glass setting tape. It is the cork and rubber type. It has a very fine cloth like mesh on one side and is plain cork and rubber on the other. Finally, to my question. Does it matter if the mesh is touching the channel or the glass? If so, which is the correct way? |
Cloth touches the channel. Cork and rubber on the glass.
Mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
| Recent Interior posts with photos |
