What Vendor - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2007, 07:52 AM
What Vendor
were would be the best place to order a line lock kit for a 85 z28. and is there any difference in brand names? Also what is the install like ?
Old 05-06-2007, 10:04 AM
DOUBLEDICK's Avatar
I got my line lock from Summit Racing.I installed it in my 58 Apache truck in about 3 hours.I mounted it on the frame next to my brake master cylinder.You should be able to mount yours on the fender skirt or fire wall close to your master cylinder.It goes in line between the master and the separator block on the front brakes.You will need the installation kit(sold separately)to make it easier.you will also need a tubing bender.I bought a chepo bender and it worked fine.It comes with a hold down switch.I just use mine for burn outs at car shows so I used a toggle switch instead of the switch that comes with it.here is the only picture I have of mine.I have a pressure activated brake light switch in line on mine so it looks like I am power braking when I do burn outs at car shows.I included a picture from Super Run 2006 burn out contest.
Name:	102_1244 (600 x 450).jpg
ID:	20986   Click image for larger version
Name:	srun06_179[2] (600 x 450).jpg
gear vendor ????? FIRECHICKEN195 Transmission - Rearend 3 04-18-2007 08:09 AM
Gear Vendor juiced66malibu Transmission - Rearend 1 05-13-2006 12:16 PM
Gear Vendor racing juiced66malibu Transmission - Rearend 1 09-15-2005 07:53 AM
gear vendor unit bailey40ford Transmission - Rearend 3 06-02-2003 11:16 PM
Vendor experience-Mr. 40's Fatstuff Randy Owens Suspension - Brakes - Steering 2 03-10-2003 05:38 PM
