I'm building an old Ford pick-up with a 429/dove-c engine and C6 trans. Any suggestions as to a good 9" rear end to run with a four link? Also I'm wondering what width would be practical. I don't have a problem with tubs for clearance, but I don't want to over do it.p.s. BYE BYE BOW TIE!!: |
Measure the truck and get one or modify one that will fit.
Troy __________________ If you don't make mistakes. your not doing anything. 69 ss rs full custom camaro 98 ISCA grandchampion 69 ss rs bb camaro wifes driver 66 Elcamino 350/all dz parts,ac,windows,loaded,my driver 69 ss chevelle bb conv.fresh frame off 26 T sedan street rod |
The 9 inch Ford did not come out until 1957. They have been installed in most everything with wheels....for years. The 57 up to early 70's F100 rear ends are almost a direct bolt in for for the 48 up F1's and the later F100's that did not have them from the factory (pre 57's). I put one in my 48 F1 back in the late 60's. They are about 61 inches (wheel mounting flange to wheel mounting flange). Later model F150's (1973 to 1986) are a little more than 4 inches wider than the early ones. Both still use the 5 on 5.5 Ford pickup wheel bot pattern.
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
