What will this 12 bolt rearend from 71Monte Carlo fit? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2004, 04:27 PM
I can buy a rolling 71 model monte carlo with a 12 bolt rearend in it what all will this width rear fit it has coil springs on it now so what else will it fit if leaf perches were welded on?It has front disc brakes on it and i think they would fit my first generation Camaro.
Old 04-22-2004, 04:43 PM
poncho62's Avatar
Wiki Edits: 5
Too wide for your Camaro, will fit Chevelles, GTO, Skylarks,Cutlass.......
Old 04-22-2004, 06:04 PM
Poncho62 is right. The only thing that will fit is from the same style F-body as what you already have.
Old 04-23-2004, 09:12 PM
ShamrockCustoms's Avatar
Lover of Classics and Customs
what are the measurements, from mount to mount???
shamrockcustoms@yahoo.com
Old 04-23-2004, 09:54 PM
Sleeve396's Avatar
It,s gonna fit 68 thru 72 chevelle skylark GTO and cutlass models.
definetely to wide for your camaro by the time you weld and narrow it you could have picked up a ready to bolt on differential from e bay or even an aftermarket supplier.
Early camaro 12 bolts are in short supply you might want to see what a complete unit from Moser might run you.
