Not sure about the vacuum. But I do know some cars, particularly higher end like the Buick, have low level indicators. Slightly lower than normal under hard acceleration, braking, or cornering can cause the light to come on. Check your fluid level and if there is a float or some other method of electronically checking the level.
Check for a brake fluid level sensor in the master cylinder reservoir. Fluid may be low and sloshing back on heavy acceleration. If fluid is low, check the brakes and check for brake fluid leaks.
Steve |
If the brake warning light is coming on during hard acceleration or at fast highway speeds, its telling you to SLOW DOWN before you get hurt or to get your foot out of the pedal before you blow something up! LOL
Mark |
Thanks for the replies everyone.
Well the thing is I'm not talking about hard acceleration, most of the time its just maintaining a constant highway speed (100-120 km/h). The fluid level looks ok. lol I don't think my park ave is even capable of hard acceleration
Doc here,
Check the Grommet area where the Low Level Brake sensor wire AND the throttle pass through..They may be chafing on one another..And inspect the sender wire back to it's source for the same.. If that is good, you may have a sender on the master cylinder (or proportioning or differential valve) Going out (slight air leak). Other than that, I' d Suggest an inspection of the master cylinder from a brake shop..It may be telling you the truth. On the other..How long since the last tune up? .. May be Due! Doc
Aftermarket Solutions Electronic & Electrical Innovations |
| brake light, please help...going crazy... | mrobby440 | Electrical | 3 | 06-18-2006 08:59 PM |
| How Does This Stuff Work? | docvette | Electrical | 3 | 06-18-2006 03:00 AM |
| location of oil warning light sender | 1983blazer | Engine | 2 | 03-21-2006 09:41 AM |
| mechanical brake light switch | colobronco | Electrical | 2 | 08-18-2004 05:54 PM |
| Brake Lights wont Light! | 97 Mustang GT | Electrical | 4 | 07-01-2003 11:41 AM |
