-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   What will clean White interior? (http://www.hotrodders.com/forum/what-will-clean-white-interior-232580.html)
f/bird 05-05-2013 07:27 PM
I'm getting ready to start the head liner and woul like any info on the rest of the interior . I'm plannig on painting the plastic parts I remove to do the h/liner and other plastic parts . I'll need to replace the d/seat cover and more than likely the pass side to look right . but the rest of the panels and rear seats are in good shape and was looking for anything that may clean them ???? Thanks for any help !
DanTwoLakes 05-05-2013 07:44 PM
What is the interior made from? If it's vinyl, I use Fantastik, or Formula 409, or Simple Green, or any one of the other degreasers on the market. If any of the parts have mildew on them I use Tilex, which already has a mild bleach solution in it. No NOT get Tilex on any fabric or carpet, it can remove the color.
Do NOT use Armor All or anything else that has silicone in it to clean a car interior.
If it's leather, you will need a good leather cleaner like Lexol, and then a good leather conditioner over that, which Lexol also makes.
f/bird 05-05-2013 08:31 PM
I have vinyl for seats and door pnls. I'll give all of those products a try . I've sprayed almost all of the cleaner stuff I had on the shelf and so far nothing has looked like it'll get them white again but I'll try leaving it set longer and so on !
