DEpends on your budget but most anything mopar will work. Try these guys for mounts, headers etc. Good stuff.
http://www.engine-swaps.com/ |
my budget is decent i would say. I wanna say i read an article that says you can take a 360 then bore it over into like a 438 or something like that. Is that true and would it be worth doing? The engine will be kept N/A and carb'd.
You can stick a 440 or stroked 400 (451) Mopar big block in there easily. All you will need is available here. You asked for the biggest engine that will fit. However, if your pockets are DEEP a 426 hemi will fit as well but be prepared to shell out $12,000-$14,000 just for the motor.
B and RB Mopars are fairly easy to find, relatively inexpensive to rebuild and make gobs of torque and HP. Centerline HotRodsAndHemis.com "Speed has never killed anyone, suddenly becoming stationary… that’s what gets you." – Jeremy Clarkson |
Centerline HotRodsAndHemis.com "Instructions are just the manufacturers opinion of how it should be put together". - Tim Allen |
What are the drawback to putting a 440 or 426 into the 68 A body versus sticking a 340 or 318 in there?
I am a newb and dont know much but I also want to drop a V8 into my 68 and pondering the pros and cons of throwing a larger engine into it. Thx |
Centerline HotRodsAndHemis.com "Remember, if you didn't put it together with your own hands, its not really yours." - Tim Allen |
I had a 73 Cuda (not sure how much different it is from a 68), but I pulled the stock 318 and replaced with a very healty 383/727 built using the "recipe" from the old Direct Connection Catalog. Fit like a glove and ran like a scalded cat, but then I wasn't very worried about corners.
| `74 `Cuda | PANAMPOP | Introduce Yourself | 1 | 09-26-2006 10:26 PM |
| 'Cuda | Boogieman267 | Hotrodders' Lounge | 2 | 08-28-2006 10:54 AM |
| Response to cuda | IgnitionMan | Engine | 28 | 03-02-2006 07:32 AM |
| 66 cuda 318 | street rodder 1937 | Engine | 4 | 05-19-2005 12:29 PM |
| 67 'cuda frame | '67 barracuda | Body - Exterior | 3 | 04-17-2004 06:57 PM |
